Ga door naar hoofdinhoud
Het Apple Extended Keyboard is een USB-A toetsenbord met volledige indeling, een aluminium behuizing en een numeriek toetsenblok.
Apple Extended Keyboard Repair Advice
I have an Apple Extended Keyboard, which works pretty well, except for the W key.
If I apply very little force, it sometimes does not work, maybe two out of ten strokes. If I apply excessive force, it works every time.
What is the recommended way to troubleshoot this type of issue? I removed the keycap, but didn't see anything obvious, such as signs of spilled liquid or excessive grime.
Is dit een goede vraag?
Score 2
1 Opmerking
Keyboard is not working
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Give this a watch! Trying to FIX : Faulty Apple Keyboard Model A1243
Sadly, the pads often corrode which is the end of the keyboard.
You might find the Silicone Dome is bad, but I have rarely found that as the case Type-F Silicone Dome - Standard
Was dit antwoord nuttig?
Score 1
6 opmerkingen:
I'd like to know for sure what causes these keyboards to fail. I have to replace mine once or twice a year. I have been doing that for 12 years.
The video at Trying to FIX : Faulty Apple Keyboard Model A1243 (https://www.youtube.com/watch?v=zxiPxyLF...) suggest water being the cause of failure. I am not spilling anything on my keyboards. To me, they seem to just wear out. Once a key starts failing, the keyboard will be usuable for a few weeks. After that, there will be at least on dead key.
The keys that fail always are among the most used letters.
So, I dunno if the liquid thing is the whole explanation.
door
@carlarogers - dust, humidity or something in the air where your system lives is what I would focus on.
door
Is there any chance, if it's one single key that was destroyed from a single splash of water (which I know I did), to repair the connection? Or is it still not worth the hassle of taking it apart?
Mostly trying to keep it out of the bin and not throw away a whole keyboard into the landfill if I can.
I own a Apple A1243 Wired 2-USB. 2007
door
@allie56770 - Did you look at the YouTube vid? It’s a bit of work to take apart and depending how far you go you might not get it back together. Other than having a second keyboard to raid for parts there just isn’t much hope. Apple designed these as throw-away’s!
door
@Danj I did. But the video doesn't show putting anything back together, they just say "if it was a couple connections to repair it would be doable." A bit of work doesn't deter me too much for a single key if I could follow a step-by-step.
door
1 commentaar meer tonen
Voeg je antwoord toe
AkhiMertail zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 58
Altijd: 3,746
