Ga door naar hoofdinhoud
The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
5 Vragen Bekijk alle
Apple Extended Keyboard Repair Advice
I have an Apple Extended Keyboard, which works pretty well, except for the W key.
If I apply very little force, it sometimes does not work, maybe two out of ten strokes. If I apply excessive force, it works every time.
What is the recommended way to troubleshoot this type of issue? I removed the keycap, but didn't see anything obvious, such as signs of spilled liquid or excessive grime.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Give this a watch! Trying to FIX : Faulty Apple Keyboard Model A1243
Sadly, the pads often corrode which is the end of the keyboard.
You might find the Silicone Dome is bad, but I have rarely found that as the case Type-F Silicone Dome - Standard
Was dit antwoord nuttig?
Voeg je antwoord toe
AkhiMertail zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 100
Altijd: 1,517
