Ga door naar hoofdinhoud
Sprint, U.S. Cellular, and Alltell CDMA version of the HTC Touch Pro (RAPH800).
1 Vragen Bekijk alle
Vraag afgerond
How do you test electronic components?
I've got a dead electronic device (HTC Touch Pro CDMA to be exact, but I'm looking for a more general solution) and am trying to figure out exactly what's wrong. I own a multimeter, but don't know precisely how to use it to test the various boards to see exactly what's wrong and what to replace. I expected there to be a Guide on here about this, similar to the soldering guide, but I can't seem to find one.
Help?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here are some good tutorials http://www.ladyada.net/learn/multimeter/ and http://www.sparkfun.com/tutorials/202. Now to test the SMD I'd invest in one of these http://www.extech.com/instruments/produc... Here http://poeth.com/smtmfg.htm and here are good tutorial on the SMD http://www.fpga4fun.com/external/SMD/smd... and http://poeth.com/smtmfg.htm Hope this is going to help you out. Big issue with any of the devices will be that a schematic is going to be very useful, but not always available. I do recommend that you start building yourself a file library and keep/get as many schematics as possible. The probable reason for the lack of a guide that you are looking for is the vast amount of different boards. Each manufacturer likes to protect there boards from copying etc.... Hope this makes sense...:-) Good Luck.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 662
