Ga door naar hoofdinhoud
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Vragen Bekijk alle
Horizontal lines on the screen after replacing the battery. Fixable?
I replaced the battery of my 2015 iPad Pro (A1652) following this video.
Everything is working great but the top 2cm of the screen are now broken and it’s only showing horizontal lines.
At first, not even the touchscreen was working but I fixed it by disconnecting and connecting it again.
That makes me think that maybe the lines on the screen could be a connection problem instead of a broken screen.
Can somebody with actual knowledge tell me if that is possible?
I was extra careful when I was detaching the screen (I even used a hair dryer) so I’m pretty sure that I did not break it… Although I’ll trust you if you tell me that I did haha.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You most likely damaged a component to the LCD assembly and you’ll need to replace the screen to fix it. Inspect the ribbon cables and connectors to make sure they’re not damaged.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Juanpi Briones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 168
