Ga door naar hoofdinhoud
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
197 Vragen Bekijk alle
What do I do with Adhesive Gasket
I have an apple watch 3 series I’m not sure what to do with this piece { Series 3 GPS) Force Touch Sensor Adhesive Gasket } I replaced my screen and the seal and it works great , but my screen is a little loose on one side .Is this what this piece is for ? What would it do to the seal if I had to take the screen off again ?
Is dit een goede vraag?
1 Opmerking:
This question was migrated from https://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
1 Antwoord
Previous versions of the Apple Watch (including the 3 had a feature called force touch, where pressing on the screen with light force would show extra options. If you need that functionality (which you probably do) you will have to open the screen back up, which will most likely break the seal. You should follow this guide, as well as the guide linked at the bottom of the page in the Conclusion section.
Was dit antwoord nuttig?
Voeg je antwoord toe
Patricia Dickerson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 62
