Soldering with broken component lead flush with pcb.
I’m working on an A1283 Mac Mini logic board.. A connector broke off leaving a post/lead flush with the pcb. I’m unable to create a connection to it. Though everything else worked prior to my breaking that connector off, I can’t get it to run. This connection leads to the power button.
How do you solder to a post/lead that’s flush to the pcb surface ? The exposed area left is about the size of a pin head. In the following photo they are circled in black
Is dit een goede vraag?
4 opmerkingen
Can you post a clear picture so we can see the area Voeg afbeeldingen toe aan een bestaande vraag
door DanJ
last time there was a omment was that the picture was out of focus. I'll post again though. The area with the two posts I want to solder looks "bare" because I've tried to scrape down to the trace thew post should be held to. Also I can barely see the posts here with glasses and magnifying glass. The photo just can't display them well if at all.
door James Walker
@danj I had a thought that maybe rework with ot air gun might be my best bet.
door James Walker
@danj there you go...
door James Walker
