Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Screen and battery replacement but not turning on
Hello everyone.
So my iphone 6 overheated in my pocket in september 2020 and it never turned on again.
Yesterday i changed the battery and the screen, i unpluuged the battery first then the screen changed the battery then the screen but as soon i cliped the battery it started to overheat in the processor area.
Today i changed the metal square from the old screen, home button, camera and speaker to the new screen(that part was wrecked of the new screen) and the overheating problem stopped so i thought the phone was going to turn on but it didn´t.
The pins on the logic board where the home botton connector connects its slightly bend, but it should still turn on no?
I can´t afford to lose the data, because i have photos in the google photos app, but the problem is that i dont know the password from that e-mail and i cant recover it.
Can someone help me pls?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you’re after data I would recommend you send it to a specialist before you cause any more damage. By the sounds of it, you have a short somewhere and shorts can cause a lot of damage. I recommend iPad Rehab, Rossman Repair Group, or STS Telecom. All of which have youtube channels you can check out.
Was dit antwoord nuttig?
2 opmerkingen:
But if that happened I can't understand how.
Although my battery came faulty, the cable was not attached to the battery
They've already sent me one new and I'm gonna see if it works
door
@Guilherme Soeiro you said the phone overheated in your pocket. Excess heat from the phone is a typical symptom of a short. That's how it happened. Go ahead and try the new battery but you probably have a short somewhere. If that battery doesn't work send it to a specialist if your data is really important to you.
door
Voeg je antwoord toe
Guilherme Soeiro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 18
