Ga door naar hoofdinhoud
2, 2,26, 2,53 of 2,66 GHz Core 2 Duo-processor gebruikt DDR3-RAM. Grafische processor is FX9400 met 128-256 MB VRAM, afhankelijk van het geïnstalleerde systeem-RAM.
Apple Install Disk versus Ubuntu EFI
Trying to upgrade the disk in the mini I ran into a problem. It seems that if Ubuntu is installed first, the Apple Install disk isn’t even seen as a bootable disk. Using Alt to invoke the boot manager, only the Ubuntu/EFI partition showed. Just as a band aid I grabbed a new disk and installed it. Then the Apple Install was bootable and the install went smoothly.
How do I get rid of the Boot Manager Ubuntu installed so I can put Apple OS on that disk ? Now if I had a drive enclosure then I’d put it in there and use Disk Utility, but I don’t. Nor do I have a two disk system except an older Mac Pro that might run OS 9.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You will need to reformat the drive fully as I outlined in your other posting: How to reformat an SSD?
Was dit antwoord nuttig?
Voeg je antwoord toe
James Walker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 335
