Ga door naar hoofdinhoud
De Bose SoundLink III, uitgebracht in februari 2014, is de 3e generatie van Bose's SoundLink Mobile-luidsprekers. Het is een moderne, minimalistische draagbare luidspreker met Bluetooth-functionaliteit.
Bose speaker not charging
My bose portable speaker is not starting after its battery reduced last night.
I hv tried changing cables also(Type C) still its not starting.
please suggest
Is dit een goede vraag?
Score 1
1 Opmerking
I've got a powercolor 2. The battery ran completely out, and now it will not take a charge or turn on (no lights turn on).
If I plug it into the computer, the computer will detect it and "set it up", however, when I try to run the Bose updater, it fails because the speakers won't communicate with the computer.
There is a popular solution if you search for it - keeping the power button pressed while plugging it into a computer and then unplugging it and letting go, then plugging it back in and pressing the power again, but this does not work for me.
I used them recently and they worked for a number of hours without a charge, so I think the battery is fine, and a quick search online shows this is not an uncommon problem for these speakers. Just want to know what to try next.
Thank you in advance!
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
hariom gangwar  not quite sure what you mean by this “battery reduced “ but I’ll assume you mean the battery went down and did not longer work. Since you already tried a different cable I suggest that you change the battery. IF nothing else it will provide you with a known-well starting point for further troubleshooting. Let us know which Bose speaker this is so we can try and help you further if needed.
Was dit antwoord nuttig?
Score 1
6 opmerkingen:
It is recently released bose portable speaker bought 1 months back.
Its battery was low last to last night approx 1-2 % and we left it for changing at night.next day onwards its not starting
door
@hariom gangwar since this is only 1 month old, return it and have them fix it under warranty. After all, you paid for that.
door
Mine is out of warranty. It’s not been charged for a couple years due to moving. What do I do?
door
It is a Bose sound link Bluetooth speaker ||| or 3
door
I’ve had it on the charger for over an hour I still have no light coming on. I understand it needs to be charged extensively but if you could tell me how long before I might see a power light emerge?
door
1 commentaar meer tonen
Voeg je antwoord toe
hariom gangwar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 42
Altijd: 3,067
