Ga door naar hoofdinhoud
De derde generatie van de Toyota Camry in alle markten buiten Japan. De jaren 1991-1996 worden ook wel de XV10-serie van de Camry-voertuigen genoemd.
Replacement of stabiliser arm rubbers
How do I replace my stabiliser rubbers at the back.
Is dit een goede vraag?
Score 1
1 Opmerking
Can you change bushings on the rear camber arm bar on a 1996 Camry? Or do you have to purchase an entire camber arm bar to get the new bushing?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I suggest you remove the tires and jack your vehicle up, or you could do it on a ramp. As long as both rear wheels are lifted the same amount, there will be no load load on the sway bar. Remove the two bolts holding the bracket in place. Remove the bracket, remove the old bushing and install the new bushing. They are split bushings and should be relative easy to remove. Remember that there are two different size stabilizer/sway bars. Make sure you measure yours so that you can get the right size. You will probably also need some WD40 or similar to remove the old bolts. Most of the time they are rusted and a bit of a PITA to remove. Replace those bolts as well, will safe you a lot of headache after. Hope this helps. Good Luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
willem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,018
