Ga door naar hoofdinhoud
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Vragen Bekijk alle
Black screen, ring, no image on the screen, burning smell
Hi, I am trying to fix my iMac which stopped working. I opened it, when I press Power button all 4 green lights turn on, and one of the parts starts burning:
https://youtu.be/QY-B5TLIU9E
Is it something that can be fixed?
Thanks!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You have a short within the logic board! The sparks are around a Via which is a connection between different layers.
At this point you’ll need to find someone with deep skills to fix this or just replace the logic board iMac Intel 21.5" EMC 2544 Vervanging van het moederbord
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, I will probably do that.
door
@earmand all of those connections and points are part of your backlight circuitry. The component right next to it is C9712.
Disconnect your LCD and check to see if that makes a difference. You also want to consider posting some really good pictures of your logic board with your question. Maybe we can find something obvious. Voeg afbeeldingen toe aan een bestaande vraag
Voeg je antwoord toe
Efim Armand zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 154
