Ga door naar hoofdinhoud
Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
20 Vragen Bekijk alle
Samsung galaxy J5 screen flickering
hello.
I have bought this Samsung Galaxy J5 2015.
it works for a minute, then the screen starts flickering with random colors and its glitching and then it turns off, but the phone is still on. (as seen in photos).
what do I do?
thanks for your help
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
You could try to mirror the screen to determine if it is a display problem or perhaps a systemboard problem, before you open up the phone.
If the mirrored image is OK then more than likely it is a display problem or display connection problem, although it still could be a systemboard problem but this is less likely.
The phone will need to be opened and the display flex cable connection to the systemboard checked to ensure that it is a secure. If it appears to be OK then the display will have to be temporarily replaced and the phone checked to see if it is now OK.
Here’s a teardown video that may be of some help.
Replacement displays are available online. Just search for Galaxy J5 2015 LCD Digitizer Display Replacement to get results for suppliers.
Was dit antwoord nuttig?
Score 5
Voeg je antwoord toe
Kapy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 543
