Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
20 Vragen Bekijk alle
Volume and Mute Button Depth is Off
I'm in the midst of reassembling my 3GS after replacing a cracked housing, and the volume and mute buttons don't seem to be protruding far enough after putting that assembly in.
I've tried and retried 10 times, with the same results each time. They both sit almost flush.
So I'm wondering - is this normal? Do they get pushed out to the correct depth after everything else is in the phone and is pushing on them?
Is dit een goede vraag?
Score 1
1 Opmerking
Try a small file to make the opening bigger
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I ended up answering my own question through testing. The answer is no.
I popped the bezel and assembly back into the old housing to see, and the buttons functioned perfectly.
So if any of you end up here with the same problem, it's because the unofficial housing is off spec.
Was dit antwoord nuttig?
Score 1
The after market casings will work. You just have to shim up the Mute, Volume, & Power buttons. Black electrical tape works great.
Voeg je antwoord toe
Ryan Rovick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 846
