Waeco cf 40 car fridge
runs on 240v but not on 12v
Fuse ok
did find on mother board the negative wire leading to fridge light has a 12v current
as does the positive
power is getting to the display but nothing lights up
it does on 240v so display is
The 7 pins all get 12v there’s no earth return from the circuit board which gets powered from the battery
the connection on the bottom right is from the compressor control panel
3rd from the bottom left is the power for the fridge light one is positive the other pin should be negative but it gets 12v
I’m wondering if this is why the control temperature panel will not power up on 12v and neither will the fridge compressor
all ok on 240v
Is dit een goede vraag?
15 opmerkingen
Hi @golde ,
Unusual that the -ve leg has 12Von it as the power supply from a car etc is +12V and usually the components in a DC system are fed +12V and the -ve side is earth or -12V with respect to the +ve side of the supply. Is this what you perhaps measured?
Maybe start at where the DC power is connected to and make sure that there is +12V DC when measuring between the +ve and the -ve on the DC input to the fridge. After that you will need to make sure that the +ve supply is going to where it should.
Post some close up images on the circuit board (both sides) back here perhaps something will be seen.
Here's how to do this. Voeg afbeeldingen toe aan een bestaande vraag
door jayeff
Ok thank you I’ll check it out
door Gerry Golden
If I put the negative lead from the multi meter on the negative pin I get a 12v positive reading on all 7 pins on the compressor board
then if I run the continuity test or diode mode I get a reading from those 7 pins
Then if I put one lead from the multi meter pin 3 and the other on pin 5 which are the common those pair give me continuity so those 2 are joined
now I’m assuming that with the red lead from the multi meter and place that on the postive feed pin from the battery and the black lead from the multi meter on either pin 3 or 5 I should get a positive 12v reading
however this postive 12v reading only happens when I put the black lead on the negative feed pin from the battery and put the red lead from the multi meter on either pin 3 or 5 which I thought supposedly common or earth pins
door Gerry Golden
The 3 black wires that go from
the control board to the compressor all give a 12v reading
However the compressor won’t run and neither will the circuit board for the temperature control
On 240v all works fine
door Gerry Golden
I double checked postive and negative are on the correct pins
door Gerry Golden
10 commentaren meer tonen
