Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De HP Laserjet Pro 200 Color MFP is te herkennen aan het modelnummer: CF145A. Deze draadloze kleuren-multifunctieprinter biedt ePrint, toegang tot apps via het touch screen en veelzijdige opties voor scannen, faxen en kopiëren.
Power Button Assembly - Where to get it?
My printer is experiencing the power button issues:
HP Laserjet Pro 200 Color MFP aan-/uitknop vervangen
The button itself is electrically fine, but one of the MOSFETs seems to be the issue. Out of laziness I’d just like to replace the entire assembly. Does anyone know where to buy a replacement?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @badlarry ,
What assembly do you mean?
Looking at the image (click on image to enlarge) in the guide for the power button board, there appears to be only the button and a LED on the board unless other components are on the other side of the board of course.
The board number for the power button board is RM1-8711. The supplier in the link is shown only to give an idea of the cost. There are others that may suit you better. Just search for RM1-8711 to get results.
If you mean the assembly where the power button board connects to, find the board number and then search online using the board number only to hopefully find suppliers.
Here’s a link to the parts catalogue for the printer. It may help a bit as it shows all the parts but unfortunately not all the part numbers, only selected ones.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi @jayeff the board is more complex than that. There are 3 transistors on the back of the board. My guess is a latching circuit. Thanks for the link to the replacement assembly!
door Deel
Voeg je antwoord toe
Matt Wood zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 400
