Ga door naar hoofdinhoud
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Vragen Bekijk alle
Can iPod touch Mah capacity battery be extended?
I have ipod touch 6th gen. The battery of my ipod has leaked. I would like to know Can 1043 mah be replaced to 1500mah battery? Is there any problem using different mah battery in ipod? Will it affect the ipod and battery if different mah used?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
As long as you go with something higher than the OEM and a quality battery you should be safe. But I’m not sure there are any reputable suppliers out there that make upgraded capacity batteries for iPods. I can buy them for iPhones at least and they have roughly 20% more capacity than OEM depending on model. You can buy them from mobile sentrix.
Was dit antwoord nuttig?
Voeg je antwoord toe
Anzar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 141
