Back camera glass cracked,water damage,tried repair phone no longer ch
My phone also has water damage, because the glass that goes over the 2 camera lenses on the back of the phone was cracked and some pieces completely missing from it and I dropped it in the bath tub. So I took the phone apart following the teardown on here
I have everything but the front screen taken off because I have cracks in the corner...so if I take if off it will need a complete screen replacement. Anyway I have cleaned off the corrosion, but I'm not sure how to check and see if anything is shorted out. When I try to put it back together though it doesn't turn on and it's not even registering when I plug the power cord in. When I cleaned the water out of the inside of the phone there actually wasnt even.much water in there so I'm not sure what the problem is. Any suggestiolns?
Is dit een goede vraag?
1 Opmerking
kirstinx how did you clean it? Remember' with water damage it does not matter how long and how much, but where it shorted out.
door oldturkey03
