How to detach clogged hose
is there a way to detach the hose from the vacuum itself to get a clog out from the bend
Is dit een goede vraag?
Hi @cefranzel ,
Here’s the ifixit Eureka EasyClean 71C Casing Replacement guide. This will help to open the casing so that the hose can be removed and cleaned.
At Step.6 in the guide the hose can be seen being held in position by being slotted into the case. You should just have to lift it out.
(click on image to enlarge for better viewing)
Was dit antwoord nuttig?
thank you very much for taking the time to answer my question!
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 568
