Ga door naar hoofdinhoud
Reparatiehandleidingen en -ondersteuning voor alle huishoudventilatoren.
20 Vragen Bekijk alle
Both fans in my bathroom stopped working
Hello!
Yesterday both fans in my bathroom stopped working simultaneously. They are on a separate switch button, so the light is working, but when I press the fan switch the light button on the one fan lights, but they don’t rotate. Where do you think is the problem - in one of them, in both, or in the installation?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @arduan ,
Please verify that there is there only one light but two fan?
Supply an image of the light/fan switches. Here's how to do this Voeg afbeeldingen toe aan een bestaande vraag
If there are 3 switches then most likely the power for the light comes from the light switch and is also multipled down to the two other fan switches so that when they're operated the power is extended to the fans.
So in the switch plate if it has 3 switches there is the power wire coming in which connects to all the 3 switches and then each switch has a wire going out, one to the light, one to the fan and one to the other fan
Usually only the active wire is fed through the switches and the neutral wire (or L2 wire ) is fed directly to the light and the fans.
Be safety aware when removing the switch plate from the wall to check the wiring, as there is exposed potentially lethal voltage there. Remove the fuse for the lights in the premises in the power box and then double check that none of the lights work. Also check that there is no separate fuse for the fans just in case they are wired on a separate fuse feed. If in any doubt call an electrician, your life is worth more
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Mihail zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 78
