Ga door naar hoofdinhoud
The Ear Force PX22 is a headset designed to provide the user with sound from games, music or movies as well as allow them to communicate through various chat programs. The headset was released by Turtle Beach in September of 2013.
10 Vragen Bekijk alle
My 3.5mm jack broke right at the top of the jack
ok so my 3.5mm jack wire broke right where the wire goes into the jack I cut it off and the wires are white with copper around it a blue wire wrapped around string and a red around string as well as a green one.. my question is I have a good jack I cut off my old Recon 70's and only matching wires are the white with copper around it the other wires seem to look like copper as well but with a clear sheathing over them please any help would be appreciated greatly
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@blazinghost the colors are not standardized. You will have to use a meter to figure out which wire is tip, ring and sleeve they go to on your Recon. Then you need to know which wire from your headset goes to the same location. Your PX22 uses a TRRS connector and the wires should be
Green - tip;
Red - ring 1;
White - ring 2;
Blue and copper twisted and soldered to - sleeve.
If you are confused about that post some good pictures of the wires, jack etc. with your QUESTION. We can always draw some pictures to explain this better. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
Bubba zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 68
