Modifying or bypass a 1/2" Headphone jack
Intergated Network AV Receiver AVR-1912
The Receiver is owned by a elder client of mine who is hard of hearing. He’s been using a 1/2” to 1/4" adapter on the Headphone Jack, damaging it twice.
I’m hoping to find someone to apply a reinforced 1/4” Jack to replace the 1/2” on the system, or can provide me other options.
My thoughts: Understanding the speakers need to mute; override the jack or suggest a Bluetooth transmitter(?) that’s patched between the receiver and speakers.
Is dit een goede vraag?
3 opmerkingen
I have the same problem with an older Yamaha rx v473 I suspect a pole contact or bypass connector disengages causing speakers to cut back in through wear withdrawing the plug partially I get one side of stereo AVR isn’t BT ready but I added a n adapter so wirless headphones are an option but buds are out Old ears don’t handle them well Tried a deep clean of the port but think it needs to be replaced I’ll test the 6.5 to 3.5 as well Any idea on how often these need to be replaced? Do they wear out?
door steeler phil
Headphone jacks will wear out but it takes hundreds of insertions. It also may be a bad solder connection. You can take it to a TV/stereo repair place and have them replace the jack unless you can do it yourself. It takes soldering.
door Whole Witt
I’m thinking it needs the new jack Any idea about the 6.5 adapters ? Can they wear out? The one on my Marantz 1711 works fine and I’ve swapped both out
door steeler phil
