Ga door naar hoofdinhoud
De Astro A40 TR-headset is een audioapparaat dat in augustus 2015 is uitgebracht en is te herkennen aan modelnummer 3AS48-XOU9N-601
Sound is severely distorted
One day I was playing rust, and then I looked left at my dog, and it tugged on the wire a little bit and then it sounded as if my astros were half plugged in, they were fully plugged in. I tried unplugging them or using them in a different device, but nothing worked. I could hear a little bit of sound, but it was severely muffled and distorted. Please help.
Is dit een goede vraag?
1 Opmerking
Probably bad sound cables or bad speakers
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
@nathanfonk sounds like you pulled some wires either fully off the jack or it’s partially loose and they are shortening the sound out. Hence the distortion. My suggestion is that you open up the jack and check it out. Should be a straightforward replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Nathan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 2,243
