Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Smartwatch van Samsung uitgebracht in augustus 2020. De directe opvolger van de Galaxy Watch uit 2018.
My watch doesn't keep charge
why does my watch not keeping charge. As soon as its off charge , the watch runs flat
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
I suppose you made sure that there are no plastic covers over the charger or debris which could interrupt the charging. I also guess that you checked that the watch is actually charging when placed on the charger.
That said you could try and force restart the watch (once while off the charger and once while on the charger) to see if that solves the issue.
Was dit antwoord nuttig?
Score 1
I recognize this is an old question. If the force restart does not work and the issue is “As soon as its off charge , the watch runs flat” it is the battery that no longer holds a charge. Start with that. If nothing else it will provide a known-well starting point should further troubleshooting be needed. Samsung Galaxy Watch3 Vervanging van de batterij
Voeg je antwoord toe
M C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 30
Altijd: 1,035
