Ga door naar hoofdinhoud
De Dodge Dakota (die tijdens de laatste twee jaar van zijn productie de Ram Dakota werd genoemd) is een middelgrote pick-uptruck van de Ram-divisie van Chrysler (voorheen de Dodge Truck-divisie genaamd). De ontwikkeling van de tweede generatie Dakota begon in 1991, hoewel ze pas in 1996 werden geïntroduceerd voor het modeljaar 1997.
fuel gauge not working
fuel gauge is not working?
Is dit een goede vraag?
Score 4
4 opmerkingen
New fuel pump and sending unit...no gas guage function.
Once it read full on an empty tank before I started the engine. After turning key on it went to empty. Gas light is always on with full tank.
Is it possible the wires were put back together backwards?
Same note...occaionally I have to pound on dash pad to get rpm and speedo to work...sometimes NO guages work til I smack the top of dash.
Help please...thanx
door
Okay...got dash to stop turning off...power harness was not connected securely...however...still have gas light on full tank and no guage function. Thinking the float is sticking against wall of tank as it is a new fuel pump and I didn't install it.
Previoust owner's grandfather did all the work on it. Well...drop the tank and see what 's what....
door
Ssssoooooo…it IS a brand new out of the box unit…what are your thoughts on this delimna?
Is it possible the idiot that installed it had placed the unit in wrong direction and the float it wedged against the wall of tank?
Drinking me insane with full tank and no guage function.
The guage works…it occasionally goes to full when ignition is off. ?????
#\€_:#! ”&\*&&€;:##_&;:” #\_.# anyway!!!
door
Could be your thermostat is sticking the truck gets hot shuts the ingine off your instrument gages don't show it being hot because the don't work
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is a pretty common and annoying problem with the Dakotas'. Most likely it is the sending unit. You will have to drop the fuel tank and replace the fuel pump/filter assembly The sender, filter, and pump are all one assembly, so you'll need to buy a whole new pump assembly to change the sender. Of course you can, and should, also check your gauge to make sure that it is working okay. Use a meter to check your sending unit and see if you have any output. If that checks out, its your gauge. Here is a pretty good write up about how to do it....Hope this helps, good Luck.
Was dit antwoord nuttig?
Score 9
6 opmerkingen:
Sad but true and not cheap. +
door
Good to know! I looked up the price of the unit (pump/filter assembly)$80-$250, depending on where you want to buy it, etc. I also look up EVERYTHING on Youtube, and it is an easy fix for the Do-It-Yourselfer!
door
mí Dakota 98 consume demasiado combustible
door
no e tenido respuesta
door
What yoh post to set the fuel pump too
door
1 commentaar meer tonen
Voeg je antwoord toe
awaesaeh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 71
Altijd: 40,427
