Ga door naar hoofdinhoud
Repair information for the Crusher Wireless headphones. Model number: S6CRW-K591. First available on Amazon in August of 2016.
Folding Hinge on Left Side Broken Around Screw Thread
The hinge on the left side of these headphones is broken where the screw threads in and holds the two parts of the hinge together. The photos show the bottom part of the hinge still attached to the headphones with the broken plastic around the screw thread. The separate piece is the top part of the hinge that fell off when the part broke but can be re-attached with screws if the bottom part isn’t broken.
I can only find parts that go around the outside of the headset band rather than this hinge which sits inside the band. Any tips on where I can get a replacement part would be greatly appreciated.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I would recommend buying a used, defective pair of Skullcandy Crusher Headphones to use as a parts donor for your pair. Check Ebay, Facebook, Craigslist, etc…
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
kick2007-uk@yahoo.co.uk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,256
