Ga door naar hoofdinhoud
De HP EliteBook 850 G2 is uitgebracht in 2015 als update van de 850 G1, met nieuwere processors en een optioneel touchscreen. Reparatiehandleidingen en gedetailleerde informatie zijn hier te vinden.
How can I reset BIOS password?
I have purchased a second-hand laptop and found the BIOS is password protected?
Is there a way to reset/remove BIOS password on this particular laptop?
I have tried removing CMOS battery but this has no effect (I believe BIOS password is held in NVRAM on this model).
HP say the only way to remove the BIOS password is to replace the motherboard which I am not willing to do as apart from being able to access the BIOS, the laptop is running fine.
Is dit een goede vraag?
Score 1
3 opmerkingen
Take it back for a refund.
door
remove bios password hp elitebook 850 g2
door
Not sure why TB rep claims it costs more than the laptop to do this, In reality, it costs about as much as lunch. Get this off amazon HiLetgo CH341A STC Flash 24 25 EEPROM BIOS Writer USB Programmer, it's 7 dollars. Then Email me or reply back here and I will instruct you how to dump the BIOS, and I can tech you to remove the password or I can do it for you. It's really not that hard. I've done hundreds of this very model.
door
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Replace the BIOS chip, or download a dump of the BIOS chip and delete the password. I did this on a laptop HP EliteBook 820 G3.
Was dit antwoord nuttig?
Score 1
You can't…
You need tools that cost more then the laptop to rewrite BIOs and then you need software versions match for firmware and INtel ME or it won's boot plus the DMI tool.
Long story short, forget about it! Return or use as is…
Score 1
1 Opmerking:
Just purchase a bios chip off ebay, and replace it, but you should have some soldier experience.
door
Just read this and it gave me a glimpse of the future of bios support from computer manufacturers. Looked pretty depressing too!
HP-EliteBook-840-G2-bios-password-reset
5 opmerkingen:
Thanks for the reply (and the link) but HP say they will only supply a SCM.bin file for machines that are still under warranty. They say the only option after this is to replace the system board which seems a bit OTT as the system does not have any other fault.
door
What is the serial number of the unit?
door
S/n: is 5CG6195QF3
door
Hmm, I tried to see if HP's website had anything to offer based on that serial number and no luck. I think you may have bought a pig in a poke. Have you any luck contacting the seller?
door
My Elitebook is still under warranty and they will not give me the scm.bin
door
HP bios bin file need to modify with LBE++ Software. It will remove the Pa$$word
Voeg je antwoord toe
Darrell Haslam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 46
Altijd: 12,670
