Ps4 got wet how to fix it
How to fix a wet ps4 pro
Is dit een goede vraag?
Hi,
It got wet but is there any fault yet? Liquid damage usually leads to corrosion on circuitry and multiple sort of faults can develop. The best course of action is to get it dry promptly to reduce the risk of corrosion.
Michael
Was dit antwoord nuttig?
Hi,
Water or any liquid (except distilled water) and electronics and electricity are not a good mix.
The impurities in the liquid causes corrosion and provides circuit paths for the electricity which were not in the console’s operating design and could damage the components. The corrosion is ongoing until it has been properly cleaned away.
First do not try to turn it on, then disconnect the power from the console.
You need to disassemble the console and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronic parts stores) to remove all traces of corrosion and water. Try not to use "rubbing alcohol" as in some cases this is <70% IPA, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA, the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards. You will also have to remove any shields that are covering some components and disconnect and clean any cable connectors etc
Hopefully after you have done all this the console might possibly work correctly again.
Here is a link to the ifixit PlayStation 4 Pro guides which may be of some help.
If this process seems too daunting, take your console to a reputable, professional electronics repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 24
Altijd: 5,175
Same thing here accept I have a older fat model Darth Vader special edition. My PS4 luckily survived but now the discdrive is clicking making ejection noises and keeps saying unrecognized disc
door Vegeeta Lionsaber
