Ga door naar hoofdinhoud
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Vragen Bekijk alle
Pins Broken that connect Logic Board to Power Supply
I was trying to upgrade the memory on the logic board. When I was trying to remove the connector from the logic board, I pushed down on the connector instead of the tab on the connector. I bent the pins almost straight down . When tried to re-connect the connector, I broke three of the pins. Are the pins replaceable or is it better to get a replacement logic board…?
Is dit een goede vraag?
1 Opmerking
Yep! You killed the connecter!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It might be possible to replace the connector. You’ll need to find someone with a junker logic board to de-solder the connector and solder the replacement on your board. Otherwise you’ll need a new logic board.
Update (06/05/2020)
The Logic board power connector is located on the back side and is a side entry connector so it’s hard to see. Here’s the location on the logic board:
Are you mis identifying the connector you damaged? How about posting a few pics so we can see what you need Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Does a new logic board come with the connector pins...? When I look at the picture of the logic board sold here, it doesn’t look like it...
door
@danj Thanks for looking into my issue... Oh, if I order a new logic board does it come with those pins. I don't see it when i blow-up the picture of it on this site...
door
The connector is soldered on and is part of the logic board. I have never seen one that was missing it! Trust me! The part is there!
door
Alright, I’m sold... I will order one today... Still kicking myself for breaking those pins like that... anyway... $99 logic board is better than $1200+ for a new iMac... L0L...!
door
Voeg je antwoord toe
KwameiMac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 84
