Pins Broken that connect Logic Board to Power Supply
I was trying to upgrade the memory on the logic board. When I was trying to remove the connector from the logic board, I pushed down on the connector instead of the tab on the connector. I bent the pins almost straight down . When tried to re-connect the connector, I broke three of the pins. Are the pins replaceable or is it better to get a replacement logic board…?
Is dit een goede vraag?
1 Opmerking
Yep! You killed the connecter!
door Dan
