Ga door naar hoofdinhoud
Why won't the wi-fi in my wet iPod touch won't work?
My ipod touch was dropped in my sink the other day. There was not as much water but I guess it got damaged anyhow..I put my ipod in rice and i blow dried it. Everything works except the wi-fi. Is there anything i can do or replace? I will not buy a new ipod touch since this one has a lot of sentimental value to me.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
angela, I think it might just be time to take it apart and clean it up. First make sure that you back your stuff up. Then follow this guide for ANY immersion. This will give you an idea of how to disassemble your device. Once you cleaned it and made sure your connectors are properly seated and that the antenna makes good contact, reassemble your iPod and reevaluate. Of course you should also try a restore of your firmware. Good Luck
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
angela zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 362
