Procedure to change the default application
Microsoft Excel happens to be my default application, I need the procedure to change it from numbers. Please guide me.
Thank you
Narayanan Lakshmanan India
Is dit een goede vraag?
Thank you
Click on a spreadsheet document, goto the menu File then slide down to Get Info your files info pane should be open twist the twisty Open with: There you can alter the application to use in this case MS Excel to alter all spreadsheets click on the Change All button
Was dit antwoord nuttig?
I am unable to understand the twist the twisty Open with.I am unable proceed further.Please clarify.
Thank you Naryanan lakshmanan India
Click on the small triangle that's called a twisty as when you click on it more information is shown user that heading.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 74
