Ga door naar hoofdinhoud
Apple's operating system for its Mac desktop and portable computers.
69 Vragen Bekijk alle
Procedure to change the default application
Microsoft Excel happens to be my default application, I need the procedure to change it from numbers. Please guide me.
Thank you
Narayanan Lakshmanan India
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Click on a spreadsheet document, goto the menu File then slide down to Get Info your files info pane should be open twist the twisty Open with: There you can alter the application to use in this case MS Excel to alter all spreadsheets click on the Change All button
Was dit antwoord nuttig?
2 opmerkingen:
I am unable to understand the twist the twisty Open with.I am unable proceed further.Please clarify.
Thank you Naryanan lakshmanan India
door
Click on the small triangle that's called a twisty as when you click on it more information is shown user that heading.
door
Voeg je antwoord toe
N LAKSHMANAN Chettiar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 40
