Ga door naar hoofdinhoud
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
28 Vragen Bekijk alle
No light when I plug in my unit!
I just took my unit out of the box, set it up, plugged it in and there is nothing happening! I pressed reset and I still can’t get anything from the unit.
I’m frustrated because I migh have to pack it up and send it back! What a wasted morning!
Is dit een goede vraag?
1 Opmerking
I also followed the instructions in the manual, unplugged it, replugged after the reset- nothing! I even tried a different outlet-still nothing!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @ Priscilla Baskerville ,
As you say you will have to return the cleaner for a replacement or a refund.
You shouldn’t have to find out what’s wrong with a new product and you don’t want to risk voiding the warranty by opening it up to find out what’s wrong
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Priscilla Baskerville zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 828
