Where to get replacement screws?
While replacing the thermal paste, I accidentally stripped one of the screws for the motherboard. I know that this is a relatively newer model, but where might I be able to find replacement screws?
Is dit een goede vraag?
To be able to help you, we need to know what screw you need to replace.
door Erik Eriksson
Why did you replace the thermal paste on such a new system?
Yes, Apple doesn't use the best of paste but it still shouldn't need to be replaced in less than a year. You also put your system at risk as Apple now has a reason to deny you warranty coverage. It's always best to wait until the warranty coverage has ended before you alter things.
Post a picture of the bottom cover marking off which screws are missing Voeg afbeeldingen toe aan een bestaande vraag
door DanJ
