Ga door naar hoofdinhoud
De derde generatie van de Samsung Galaxy Note phablet-serie, uitgebracht op 25 september 2013. Identificeerbaar aan het modelnummer N9005.
Why is my screen blank?
why is the screen blank when the phone is on?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi,
Has the phone been dropped or gotten wet at all?
Try shining a torch at an angle close to the screen to see if you can detect an image at all when the phone is on.
If you can see an image, (or even if you can’t) the phone will have to be opened to further diagnose the problem to isolate where exactly it might be, in the LCD display, the LCD display flex cable connection to the systemboard or the systemboard.
As a DIY repair all you can do is to initially check if the LCD screen flex cable connection to the systemboard is secure and if so then temporarily replace the screen assembly to see if it works OK or not .
Here’s a link to the ifixit Samsung Galaxy Note 3 schermmodule vervangen guide, which may be of some help.
Replacement display assemblies are available from ifixit (limited stock - click on the parts link in the guide to check what may be available for your particular model) or online. Just search for Samsung Galaxy Note 3 display assembly to get results for suppliers of the part.
Was dit antwoord nuttig?
Voeg je antwoord toe
bigjohnson6767 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 230
