Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Can USB-C issues be caused by low battery capacity?
Hi all,
Recently out of nowhere my MBP 13” (function keys, 2017, no Apple Care, out of warranty) started acting out in the following combination of ways.
THE LIST OF ISSUES:
  • Both ports stopped recognizing external display using the usb-c to hdmi adapter I used reliably a while before
  • Around the same time my battery started reporting “Service Battery“ state
  • The USB-C port closest to user (front) is only taking ~5V when charging, while the other USB-C port (back) is charging at ~19V (I have current measuring USB-C device)
  • If I want to use external SSD for backup/data transfer it works on both ports but sometimes I need to plug the other port for charging for device to be recognized
  • Up until recently, I also noticed that sometimes MBP would shut down when I would close the laptop instead of going to sleep (though after resetting SMC/NVRAM I never experienced this again)
WHAT I TRIED:
  1. resetting SMC/NVRAM
  2. updating system to the latest MacOS version
  3. running diagnostics (only service battery was reported, which later on disappeared)
  4. plugging/unplugging cords in different combinations
  5. using different usb-c hub with direct power-in that used to work before as well
Here is the charging report from CoconutBattery
For back USB-C port:
For front USB-C port:
QUESTION:
Is there any chance this issue will be resolved (especially the one about recognizing external display) if I would just replace MBP battery?
Or is this almost definitely characteristic of logic board issue?
I was thinking about taking up a task of buying a replacement kit and replacing the battery myself while in self-isolation due to pandemic, but would not attempt replacing logic board myself.
Thank you in advance for your help!
Is dit een goede vraag?
Score 5
4 opmerkingen
Let's check the battery & charging logic. Install this gem of an app CoconutBattery. Post a snapshot of the apps main window for us to see with the charger in each port. Voeg afbeeldingen toe aan een bestaande vraag
door
@danj Thank you for the suggestion. I just updated the initial question with the screenshots from CoconutBattery.
door
Georgiy I have the same make and issue, did you found a solution?
door
Same here. Any suggestion ?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Well, that’s interesting! One port is charging with 2.26 Watts (I assume its the 5 Volt port) and the other 4.77 Watts 19 Volts on the good.
Sadly, I haven’t seen this problem, so you’ve taught me something new!
Each port has its own power controller which then feeds the logic board its power. So I would say your logic board needs attention.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thank you Dan! The weirdest part about this is that it appeared out of nowhere, and I'm in general extremely careful with the laptop. That said I do use it for a lot of computationally heavy tasks.
So you think there is little chance that replacing battery will resolve the issue?
door
The batteries charing logic is on the other side of the USB-C port power controllers, as such it won't explain the difference between the ports.
740 cycles is still less than the expected lifespan of the battery (1,000 cycles). So I would wait awhile before going down that path.
door
Great, thank you! I'll wait till they reopen Apple Stores and look into full check-up then.
door
Georgiy, did you ever find anything more about this issue?
door
Hello, i have another kind of issue with mine ..
When i plug one or second usb-c connector (under monterey), my macbook shutdown and don’t restart it is possible that this kind of issue could be possible with oxydation of both ports.
I try to dismount my laptop soon to see if ports have oxydation or altered by humidity, in the tattoo woorkshop of my son it's too wet.
Thanks in advance for your answer.
Update (01/30/2022)
when i use quickly booth of this ports plug and unplug charger, i can read in charge or out of charge under battery notification. i suggest a trouble of oxydation and a bad contact with charger, before shutdown probably due to violent electrical short circuit.
Voeg je antwoord toe
Georgiy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 58
Altijd: 2,288
