Ga door naar hoofdinhoud
Reparatie- en demontagehandleidingen voor Epson-printers. Het bedrijf werd in 1942 opgericht als Daiwa Kogyo, Ltd., maar fuseerde in 1959 met een ander bedrijf om Suwa Seikosha Co., Ltd. te vormen.
error light paper blinking
Hi,
My epson printer L3110 having light paper blinking but already check all is good. No paper jammed or any object inside the paper slot. I check with system show : MEMORY CARD IS LOADING ERROR
so what should I do to get the printer is normal? And what the solution to solve this error.
This is new printer as i buy last month.
Hope can help and run as normal.
thank you
Rafi Haron
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Het nuttigste antwoord
Knowing the model number is always helpful.
This can sometimes revive epson printers that are being difficult…
https://epson.com/support/updating-your-...
Was dit antwoord nuttig?
Score 1
The way to solve this problem is quite easy if you want to follow the procedure I explained like this, open explores -> this PC -> Manage -> device manager -> print -> update driver.
After the driver is updated, if it doesn't work, just uninstall the driver then download it again by clicking via the link below:
download driver epson l3110
Score 1
i know ,that probel will make you job disturb, i want to give suggestion you can find theright driver for your printer driver. I know but it is for model epson l1110 may be next time i will find good driver source for your epson l3110
Rafiharon bom dia,
deve ser algum sensor q esta com problema em sua impressora, e por isso acusa o erro de papel, verifique tambem se pode ser a mola do sensor de papel, pode ter escapado.
katika epson l3110 taa ya ink na taa ya paper zinawaka pamoja nini suluhisho
Voeg je antwoord toe
Rafiharon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 35
Altijd: 4,447
