What SSD will fit and can I increase RAM past the 4 GB max?
I have replaced the battery but still get spinning beach ball forever. Thanks in advance for any suggestions
Update (03/14/2020)
OK finally got the RAM installed, but the top chips don’t appear to have seated correctly and I cannot pull the sides out enough for it to pop up like they did originally. It seems to be caught on the back/bottom of the enclosure they are to seat in.
Suggestions welcome, as I’m unfamiliar with how much pressure to apply to get out?
The computer is registering only 4 gig of memory and one slot is empty.
I also tried to back post the clock and date but the internet wouldn’t connect after I did this so I turned it back for now.
Is dit een goede vraag?
3 opmerkingen
Does the DIMM tilt forward? If not the side clip didn't release.
Is the DIMM sitting evenly within the socket? If not you'll need to shift it as its wedged in.
door Dan
It is kind of wedged out where moving the side clips doesn't have any effect. The DIMM seems to be wedged against the back of the enclosure. Is it substantial enough to wiggle without damaging it? @danj
door rcfoley
I'm thinking you have the wrong memory modules! Take a picture of the original and the new unit with the gold contacts facing each other and touching evenly, take a second showing the labels and a third showing the chip markings clearly. post them here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
