Ga door naar hoofdinhoud
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Vragen Bekijk alle
How to connect ThunderBolt Display to MacMini through Firewire
Hello,
I have a MacMini 2012 which it’s thunderbolt chip is not functioning. I really do not want to spend money on repairing it. I also have a Thunderbolt display which I was working with it before the MacMini chip broke.
Now would you please let me know if there is a way to connect my Thunderbolt display to my MacMini with a adapter from TB2 to Firewire or HTMI ?
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You facing the same issue as having two people who can’t speak the others language. There is just no way for the two to have a conversation! You can’t use the FirWire connection to connect a miniDisplayPort or Thunderbolt display. There is just no means to make that work.
Your system does come with a HDMI port which you can connect a HDMI connected display. The other alternative is connect a second Mac via Ethernet between the two systems and then use Remote Desktop to then run your apps via the other Mac. Basically, running it headless. Thats what I do to manage my Mac Mini as a media server. Here I run iTunes to download and mange my music, video and podcast media.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Dear Dan,
Thank you for the straight forward answer. Then I would need to weather buy a new Mac Mini or forget using my Thunderbolt display.
All the best,
Al
door
Sounds like you had your heart set on the Thunderbolt display. Yes its a great display!
Where do you live? Country and nearest city? Maybe someone can fix your logic board or see if a replacement logic board would be possible. Either option should be cheaper than getting a new Mac mini, unless yours is just underpowered for what your needs are.
door
Voeg je antwoord toe
A.Ch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 303
