Ga door naar hoofdinhoud
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
How to connect ThunderBolt Display to MacMini through Firewire
Hello,
I have a MacMini 2012 which it’s thunderbolt chip is not functioning. I really do not want to spend money on repairing it. I also have a Thunderbolt display which I was working with it before the MacMini chip broke.
Now would you please let me know if there is a way to connect my Thunderbolt display to my MacMini with a adapter from TB2 to Firewire or HTMI ?
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You facing the same issue as having two people who can’t speak the others language. There is just no way for the two to have a conversation! You can’t use the FirWire connection to connect a miniDisplayPort or Thunderbolt display. There is just no means to make that work.
Your system does come with a HDMI port which you can connect a HDMI connected display. The other alternative is connect a second Mac via Ethernet between the two systems and then use Remote Desktop to then run your apps via the other Mac. Basically, running it headless. Thats what I do to manage my Mac Mini as a media server. Here I run iTunes to download and mange my music, video and podcast media.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Dear Dan,
Thank you for the straight forward answer. Then I would need to weather buy a new Mac Mini or forget using my Thunderbolt display.
All the best,
Al
door
Sounds like you had your heart set on the Thunderbolt display. Yes its a great display!
Where do you live? Country and nearest city? Maybe someone can fix your logic board or see if a replacement logic board would be possible. Either option should be cheaper than getting a new Mac mini, unless yours is just underpowered for what your needs are.
door
Voeg je antwoord toe
A.Ch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 383
