Error Code 0x80070570 upon Windows 7 installation
you can google the specs for my acer aspire. someone hacked into my computer a few days ago, so i backed up all my programs and files on to a 1tb hd external, popped in my windows 7 ultimate 32bit/64bit disc (this disc worked while bootcamping my macbook pro 13 inch april 2011) and decided to tell my computer upon restarting and booting form install disc to format my hard drve. it told me some stuff about loosing information blah blah blah and i continued to install windows 7. it copied the files and continued to expand them at 0% for a long time before telling my this:
"Windows cannot install the required files. The files may be corrupt or missing. make sure all the files required for installation are available, and restart the installation.
Error code 0x80070570"
whenever i try checking the drivers using the windows setup program it says there are no drivers.
**EDIT**
ALSO POSTED ON MICROSOFT ANSWERS:
how can i install fresh windows 7 on my acer aspire 5536 when trying it the first time formatted my hard drive and erased everything?
acer aspire 5536/5236 not sure if it is 5536 or 5536G model number ms2265
3g ram AMD something 320 gb hard drive (win7 setup on boot with disc says there is a 100mb partition i cannot delete or format and that the rest has only 298gb left, where is the other 20?)
ok heres everything that has transpired with this computer.
bought from ebay several months ago. came with win 7 ultimate. added military MacAfee. came with CCleaner and Anti-malware Bytes software which expired just before crashing started. i liked that program.
started crashing. viruscan picked up no viruses. no registry errors. there were unused extensions picked up by a program called CCleaner that came with the laptop.
i decided to put in my windows 7 64/32 bit disc. i believe the computer originally had vista but had been upgraded to windows 7.
repair computer option leads me to an error i dont remember after wiping the hd and from then on, installing vista ultimate or 7 ultimate 64bit or 32bit or my 64/32bit discs leads to install option that results in "Error code 0x80070570 blah blah blah" and trying to install with win xp pro or 98 lead to the imfamous blue screen error that says to restart try again scan for viruses and try again.
acer website offers driver downloads for this model, but warns against using them unless instructed by customer service rep to use them. i downloaded them all., for both the 5536 and 5536G and i downloaded the BIOS as well. will they help me and if so how do i use them?
PhoenixBIOS does not have any changeable settings that help with trying to install any of my windows
turning the computer on with no disc or anything tells me that bootmgr is missing, press ctrl alt delete to restart computer.
i just want to fix this at home without paying for some other nerd's paws in my machine and without having to pay $99 or so for acer tech support or anything like that.
should i buy a new hard drive?
i googled the error code and got some directions that do not work or only work for Dell laptops with this issue.
is it because of my media? all of my windows 7 ultimate discs were downloaded from TPB Computer-User as isos and burtn with PowerISO. the 64bit disc i burned also worked for bootcamping and VMWareing my macbook pro 13inch. like i said i have a 64bit iso, a 32bit iso, and a 32/6bit iso, plus vista ultimate and xp pro and windows 98.
i did burn the 64b/32bit with the computer in question at 4x. there was the option to go to 2x but i used 4x instead. my other computer burned 32bit at 4x at the slowest. ive tried burning 64 and 32 with my mac but the discs are always messed up.
most of the solutions i find for this 0x80070570 thing involve a computer that still HAS an operating system downloading a fix or file or program and fixing itself, but this machine doesnt have an operating system anymore (WHY ME???!!!)
im wondering if there is the option to hackintosh this computer is possible. i do have an osx10.6.4snoleopard disc that came with my mac. anyone think this possible? fake mac boot on acer aspire 5536?
if the hard drive is sata, i can remove it and plug it into my seagate goflex sata harness that the 1tb hd it came with plugs onto. could i plug it into my desktop and reformat it as an external hard drive?
would burning win 7 to my 8gb flash drive help?
im running out of options and hair.....
i hope i didnt forget to include anything......
**EDIT 2**
OKAY i just pulled the ram and looked at it. LOOKS fine but that doesnt mean something isnt wrong.
i googled my hard drive found one on best buy cheap. its a wd scorpion blue 320gb hdd and is easily replacable.
i pulled the hard drive and it fits on the sata reader for my usb3.0 goflex freeagent 1tb external hd. i plugged it into my other computer (hp pavilion p6612p-b pc bundle) i ran a quick format of the drive by right clicking on the drive it is plugged into. i hope this fixes it....
and am currently burning another copy of win 7 ultimate 64/32 bit at slowest possible speed.
Is dit een goede vraag?
4 opmerkingen
You should make this an answer ot--your research deserves an uptick.
door rj713 Deel
huh? i am about to edit this post.
door Daniel Deel
ram memory,replace
door zoranristovski777 Deel
Try the fixes here: https://softwaretested.com/windows/windo...
door QVS social Deel
