Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor auto's geproduceerd door Citroën.
The car doesn't start
my Citroen c8 doesn't start?
Is dit een goede vraag?
4 opmerkingen
Could we possibly get some more information?
door
For instance--does the engine turn over?
door
the engine doesn't turn over
door
Since you are really not telling us anything about what your car does or doesn't do. Start witht he basics. Do you have any battery power? Do your dashlights come on? Do your lights come on? Do they go dim when you try to start your car? You need to give more info if you want a definite answer.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
With a broken timing belt you will have:
bent valves
damaged pistons
possibly bent con rods
Or just a useless timing belt. Do not try cranking the motor over (might lead to all issues mentioned above). Take it to a capable garage!
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Extremely good advice--you can total a engine with a bad timing belt. +
door
Insert your car's key into the ignition switch and turn clockwise until you hear sounds from the engine bay.
Score 2
1 Opmerking:
the timing belt is broken and it damaged the engie
door
If you have a keyless push button ignition it requires you press on the brake to start. There's a brake pedal switch that performs this function which is a common problem and quick repair.
Score 1
Voeg je antwoord toe
solomon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 2,293
