Ga door naar hoofdinhoud
De RCX 1.0 is het eerste model in de RCX-lijn van programmeerbare Lego Mindstorms-stenen.
How to fix RCX 1.0 I.R. problem?
The LEGO RCX 1.0 powers ON and all built-in programs work well. But when I tried downloading or even communicating with the I.R. Tower, the RCX wont respond! =(
Which component should be replaced or re-soldered? Please anyone... help pls. I just need to know.. which hardware component is at fault... so I can fix it.
Thank you =)
Is dit een goede vraag?
Score 1
3 opmerkingen
hello, i have the same problem like sirgilberts.
My RCX 2.0 shows a icon for IR detection and my older RXC 1.0 doesnt react - i have three of them but they wont work.
door
I'm working in a Schoolboard and i have 6 RCX 1.0 bricks with the same problem. I am interested if someone finds a solution.
door
The main problem is that Windows does not recognize the IR tower. This happens with versions newer than XP.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
http://www.squidoo.com/collected-info-on...
it sounds like it may be a software problem, make sure you're up to date with any drivers for your console
Was dit antwoord nuttig?
Score 1
1 Opmerking:
also take a look on here http://messageboards.lego.com/en-US/show... for some more ideas.
door
Voeg je antwoord toe
sirgilberts zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 3,223
