Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Which Hot Air Unit?
Im looking into an aoyue hot air unit and was wondering which one would be best for iphone logic board repair?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Jared, I purchased this one mostly for reflow and this for the repairs. Not a bad price and relative easy to work with. Hope this is what you are looking for.
Was dit antwoord nuttig?
Score 2
A heatgun on medium heat is usually your best bet
2 opmerkingen:
you talking a regular heat gun i can use for removing chips off logic boards?
door
It actually does work, but I would suggest if you can afford proper equipment or have it, use that, many other people here had success using a heat gun, but make sure you are careful of the soldering pads, they can come off
door
Voeg je antwoord toe
Jared zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 366
