Screen replacement tools ands part
Cracked screen I need parts
Is dit een goede vraag?
Hi,
There are suppliers online.
Just search for Moto Z4 LCD part with tools to get results.
Here are just two suppliers found on a quick search
Was dit antwoord nuttig?
InjuredGadgets has the screen as well but I would get the Genuine and not the other cheaper one from them.
I think iFixit sells a wide range of tools and replacement parts, if that’s what you mean.
If you read carefully no that not what I mean ...moto z4 is the title
Screen Replacements tools and parts ..that the subject...and finally
Cracked screen ,,I need part that's the message..
Both of those examples are LCD screens which are for the cheaper Moto z4 play. The original Moto z4 has an OLED screen. Make sure to look out for this because as far as I've researched, they are not compatible with each other.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 3,690
6 opmerkingen
InjuredGadgets.com
door icedrgn86 Deel
So where is the guide to fix it?
door Ruppert Wahner Deel
Could not find any guides there.
@ruppertj It opens up just like the Z3, but the ribbon is on the right side. I would recommend disconnecting the battery first.
door Menelik Seth Deel
Well this was a day late and a dollar short, It would have been helpful if the cause of the screen separating from the body was caused by the battery expanding from gas build up. This did not effect the battery performance but it surly is the cause of the screen separation. This should be noted as the main cause of screen separation and the screen cannot be replaced until the battery is replaced. I wasted two screen replacement kits Z2-Force and Z4 because of the batteries had expanded. This was the cause in my Z2 and Z4 screens to separate.
1 commentaar meer tonen
