Ga door naar hoofdinhoud
10,1" Android-tablet uitgebracht in juni 2011. Samsung GT-P7510MA
Touch Screen Replacement problem
Afbeelding
I replaced the touch screen on my tablet and now have a thin verticle line on the left side of the display. Other wise works ok.
Is dit een goede vraag?
2 opmerkingen
Did you buy the LCD and digitizer unit as one or the separated version?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Tracy Walker double check your work and check the connector. Make sure that everything is properly seated and that the LCD connector itself does not have any bend pins, debris etc. if everything checks out okay then the issue is a bad LCD.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Everything looks good connector-wise. The digitizer worked fine before I replaced the touch screen; even worked ok with the old, cracked screen in place. Like you I can only conclude that in the process of changing to the new one, something occurred to damage the LCD. The connector for it was never unhooked, so can't imagine how it got damaged. ..
door
Can agree on that, something happened during the install and the lcd got damage.
door
Voeg je antwoord toe
Tracy Walker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 30
Altijd: 400
