Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in juni 2016, te identificeren aan modelnummer A3003 in Europa, A3000 in China en Noord-Amerika (volgens https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Digitizer does not work after screen replacement
I replaced screen and digitizer and it seems everything went fine. The phone turns on but the touch doesn't work, the back and all app button do work. I tried doing a factory reset but it stills doesn't work. What could be the problem?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi Neil,
I would suggest disconnecting and re-seating the display cable. Carefully check the connector for any debris—the pins on the connectors are tiny.
OnePlus 3 scherm- en digitizer-assemblage vervangen
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hello Arthur,
I tried disconnecting and re-seating the display cable as you suggested but still nothing. Could it be a motherboard problem or should I send back the display+digitalizer and try with another one?
door
Hey Neil,
It could be a motherboard, though I'd think that the display may have a slightly higher chance of being the problem. Does the original screen work enough to be used as a test? Unfortunately with how the replacement is set up, it's not easy to swap displays.
door
Voeg je antwoord toe
Neil Considine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 546
