Ga door naar hoofdinhoud
Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Vragen Bekijk alle
Note 9 wont turn on. Left on 0% charge
Hello, I have note 9 sm n960u and its not turning on completely dead. No light no vibration nothing. I have tried all troubleshooting steps tried many different cable wireless chargers and everything i possibly could so to fix it but it wont respond. As this device was bought in US and i am not in US any more so i cant send it to service center so i went to a local repair shop and the guy there told me thats its the board dead. Now i have no idea what to do as the device was running perfectly when i kept it aside after complete discharge. I would be glad if anyone can help me with hardware based trouble shooting. I still havent tried new battery as the guy told be thats its with motherboard so should i trust him or try a new battery? Is there any way i can check shortage with multimeter to confirm myself? I would be happpy if someone help me out witht this
Is dit een goede vraag?
4 opmerkingen:
are you using the original charger or a Fast Charger that goes up to 9V, 2AMPs?
door
@conlledo yes i am.
door
Any one has this problem or its only me?
door
I replaced battery and charging port still charging but won't charge beyond 0%. When I changed battery it started with a small amount of charge. Left it on charger to charge to 100%. Returned to it after an hour to check progress and it was not showing percentage. Refused to charge and now stays at 0% even in safe mode.
door
Voeg een opmerking toe
1 Antwoord
@mustaqeem the instructions from My battery died to 0% and won't charge now, wired nor wireless. would only work if your battery was discharged below its charging threshold. It will not fix a battery. My suggestion would be that you start with a new battery. Your battery may have shown a proper voltage but may not accept a load or fail under a load. Replacing the battery will at least give you a known well starting point should further troubleshooting be needed. Check this teardown Samsung Galaxy Note9 Teardown to see what is involved with that.
Was dit antwoord nuttig?
Voeg je antwoord toe
Mustaqeem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 40
Altijd: 2,982
