How to fix all screen vertical color lines in the screen?
Model no. TX-47AS650E Panasonic Viera 44 inch.
Is dit een goede vraag?
Prem Bhandari this could be a bad T-con board, bad main board, bad LVDS cables or even a bad panel. Remove the back cover from your TV and take a look at the cables first. Make sure they are properly connected, no corrosion etc. After that check the boards for obvious damage. Post some good pictures of your boards etc. with your Question so that we can see what you see. I’d start with a T-con board and work my way up from there. At least that way you will have a known-well starting point. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 348
