Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Dim screen Not 6r8?
I have a 3gs with a dim screen so i figured 6r8 coil i have done 2 before so i knew the symptoms. I replaced it and it still has dim screen i even tryed a different coil and still dim screened what else could it be?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
3GS backlight issues seem to be caused by Display LCD, 6R8 coil, or IC 109B. If your LCD Display is good, then hopefully it is the 109B chip. This chip is right next to the coil.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
I used one off a junk board and when I went to take the chip off my good board i pulled off one of the two pads underneath!!! Is my board junk now??
door
Can anyone help me?
door
Jared check on this Anyway to reattach solder pads? and click on the link provided by ABCellars. Little bit more on the repairs possible right here http://home.comcast.net/~machrone/bjr/mi... but definitely not as neat. Good Luck
door
I think you need to comfirm your 6r8 is original, since many seller online sell 6r8,but a little bit difference with the one on the 3GS motherboard
I check a site ,the picture is same as on 3GS motherboard, and I get the items from them, it is original and can work
here is the link
http://wiisingonline.com/iPhone-3GS-6r8-...
Voeg je antwoord toe
Jared zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 3,578
